跳转到主内容
Repair guides for the Samsung Galaxy J5 (2015), released June 2015.
45 个问题 查看全部
My phone is seriously overheating instantly, any fix?
Hi, so my device starts overheating instantly whenever I put the battery in (didn’t even turn the phone on), another thing I noticed is the camera flash led turns on when I place the battery. simple sequences : phone is off —->puts battery in (phone still off) —-> camera flash led turns on and overheats instantly (phone still off). Hope anyone can help solve this or at least help identify the real cause. Thanks in advance.
Update
So, I forgot to add, that I used a different battery and that didn’t fix the issue, another thing I suspect is my child used his fast charger to charge the phone for a week which isn’t supported by the phone resulting in the first battery death, after that I bought a cheap battery off ebay and died too after putting it in and powering on the phone 2 times, now I bought another original battery and I saw that the issue is still exists, so I only placed it in and powered on the phone to verify if it’s still functional (which it is) and took it off don’t want this one to die too.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
It seems to be a battery or Motherboard issue, to issolate the issue can you use a different battery for the moment and see if the issue still continues.
这个答案有帮助吗?
得分 0
3条评论:
Ok I think I should add more details my bad, let me help you help me, plz read my next comment.
完成的
tl;dr MB issue
完成的
Great you were able to issolate, hope the MB is not that expensive for your model.
完成的
添加一条评论
添加你的答案
Robert Kyosi 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 10
总计 195
