跳转到主内容
在2017年6月,Apple更新了13寸的MacBookair,他换上了更新更好的Intel Core i5处理器,让性能和电池续航时间提高。
423 个问题 查看全部
MacBook Shuts down randomly and won’t start back
Hey,
My MacBook Air was working fine for sometime, but, suddenly it shuts down. I tried to start it again, it started however but again it shut down.
I performed SMC reset a couple of time but still it has the same problem.
And now it is not even starting backup, and some times it does, it again shuts down randomly.
SMC couldn’t resolve this issue? Also I’m not sure whether the SMC is performed successfully or not?
In addition, this happens even when the power plug is plugged in and the power plug is only showing the LED light if the laptop is turned on otherwise it just doesn’t even show the LED light.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
6条评论:
What is the color and the brightness of the MagSafe LED?
完成的
And also I’m not able to know whether it is getting charged or not as the led light doesn’t turn on, even after plugging it in AC supply and I don’t think it is adapter’s issue because it was getting charged till yesterday, even after the random shut down but now it’s showing no sign of charging.
完成的
How did you solve the problem?
完成的
@yash Jain I am suffering from same type of problem please tell me how you shot out
完成的
@Chandrajit Satapathy - Rahel also asked about a year ago and he too never got an answer from Jain.
How about creating your own question will all of your details so we can help you. Answers
完成的
显示更多的1条评论
添加一条评论
2个答案
Possibly your MacBook is out of power. Let it charge for 1 hr. Don’t disturb your machine.
Is there any heat issue?
Check the CPU temperature with HW MONITOR.
这个答案有帮助吗?
得分 0
8条评论:
HW MONITOR is a Windows PC app which won't work here under macOS.
完成的
@me_ravi - Thats better! HWSensors
But even still, that's assuming you can install it and in truth this is not the ideal way to deal with this type of problem.
Lets leverage what the system offers for diagnostics first the MagSafe LED is the first. The second would be to install an app that can read the Battery and Charger info. I like this one CoconutBattery
完成的
No there is no heat issue. It’s normal. Moreover how can I install, my mac is not even starting.
完成的
LED doesn’t matter
It just indicates
If it conducts copper, full- green, not charging empty
Must be connection issue.
完成的
显示更多的3条评论
添加一条评论
@yjain_4 - So you are not getting any light from the MagSafe charger. Let’s work on that as you need to get something.
Review this Apple T/N Apple Portables: Troubleshooting MagSafe adapters Make sure the cable is not damaged in any way and the pins of the connector are good.
On the system make sure the contacts are clean and not burnt. If they are burnt you’ll need to replace the MacBook Air 13" (Mid 2013-2017) I/O Board and here’s the guide you’ll need to follow MacBook Air 13" Early 2015 I/O Board Replacement
MacBook Air 13" (Mid 2013-2017) I/O Board图片
产品
$79.99
这个答案有帮助吗?
得分 0
2条评论:
Will this I/O board charge me if my mac is in warranty? It won’t, right?
完成的
If you have AppleCare+ I would not do anything! Instead take the system into an Apple Store or authorized service center. Let them fix the system under warranty! I like Free over having to buy something!
But!! If you've used a cheap knock-off charger or got your system wet then they could deny your coverage.
完成的
添加一条评论
添加你的答案
Yash Jain 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 3
过去 30 天: 4
总计 2,153
