跳转到主内容
加入维修社区 - 创建账户
2006年11月, Wii 在北美市场发布。这是任天堂第一款支持直接连接互联网的电视游戏主机。该主机支持在线游戏,以及通过 Wii Shop Channel 分发数字版游戏和媒体内容。
Grinding noises when tilted
Hello, I have a Wii that makes grinding noises when it's tilted diagonally while it spins the disc. Is this normal? (when placed normally it doesn't make these sounds)
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
This is normal for the Wii, as well as most slot loading CD drives. The Xbox 360 was notorious for killing disks when tilted. My solution: don’t tilt the console while in use.
这个答案有帮助吗?
得分 0
1条评论:
I'm pretty sure it didn't do this before, I must note that I've taken this apart myself two times, and I've also removed the metal plate that has the "disc sucking" mechanism as well. Just want to make sure everything is ok and I didn't mess anything up.
完成的
添加一条评论
添加你的答案
Miguelito G. 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 82
