跳转到主内容
Model A1311 / Mid 2010 / 3.06 & 3.2 GHz Core i3 or 3.6 GHz Core i5 Processor
343 个问题 查看全部
The screen went all Black but you still hear sound
I had went to work and my cpu was on but it would go to sleep and when I shook the mouse it would come on but one day I came home and the screen stayed black but you could hear sound the cpu was getting very hot to the touch too
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
I assume that monitor is the problem here. Before going furthermore and troubleshooting confirm if it is just the monitor that does not working. If it is not just the monitor it can be the BIOS misconfiguration in motherboard. Clearing CMOS might fix the problem. After that Press and hold power button for more than 5 seconds. Then try to power on and see if it is boot normally.
这个答案有帮助吗?
得分 0
1条评论:
@elsa_bailey - Mac's are different than Windows PC's. Here we don't have an accessible BIOS setup. We do have a NVRAM or PRAM which holds settings and you can reset it Reset NVRAM or PRAM on your Mac and we have a SMC chip which may need resetting as well How to reset the System Management Controller (SMC) on your Mac
But from what Jeromy wrote in his question I don't think resetting these will fix his issue.
完成的
添加一条评论
@thelife - Do you have access to a external monitor which you can plug into your system so we can see if the display has failed. The other direction is to take a flashlight resting on the display as t sharp angle to see if you can make out the faint image of your desktop icons. If you can then you know the displays backlight has failed. If you can’t you can have a bad dedicated GPU board.
The next test I would try is to see if your system can get into Target Disk Mode. Restart your system and hold the ‘‘‘T’’’ key are you able to see the FireWire Icon on the screen? If not your logic board has an issue
Let us know what you discover.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Jeremy 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 7
总计 1,205
