跳转到主内容
发布于2017年6月,iPad Pro 10.5寸替代发布于2016年的iPad Pro 9.7寸。
145 个问题 查看全部
Backlight and touch working but no image
Well maybe you can help me.
The display on my iPad Pro 10.5” stays black even though the backlight is on. Sadly it is not displaying anything. The weird thing is that the backlight as well as the touch are still working (tested it with voice over).
I already tried disconnecting and reconnecting the display cables. Do any of you have an idea how to fix this?
Restore in iTunes didn‘t help either.
Thanks
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
Hi @michael_r96
The only thing I can think of is some type of LCD failure or graphics issue with the logic board. If you have already removed the display to reconnect the cables, then you should order a replacement screen from a trusted source to see if it will fix your issue.
Here is a part I would trust:
https://www.mobilesentrix.com/lcd-assemb...
Best of luck!
这个答案有帮助吗?
得分 1
4条评论:
Hi @michael_r96
The only thing I can think of is either your LCD controller has failed or the GPU on your main logic board has stopped working. If you already have the device open, I would recommend you install a replacement screen assembly from a trusted source and see if that fixes your problem.
Best of luck!
完成的
Thanks, I’ll give it a try
完成的
Well I replaced the screen and since then it’s working like a charm. Looks like something on the LCD Board itself was broken
完成的
I've had this exact problem with now 5 premium screens from mobile sentrix and injured gadgets. Either works for a week and goes out or doesn't work at all.
完成的
添加一条评论
最有帮助的答案
did this happen after a screen repair
这个答案有帮助吗?
得分 1
4条评论:
no it didn’t
完成的
I just can‘t wrap my head around it. I did not replace the display or anything yet only the backlight and touch is working
完成的
how do you know the touch is working if you do not have any display
完成的
Voice Over. It’ll tell you if you touched something
完成的
添加一条评论
添加你的答案
Michael Ritz 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 8
过去 30 天: 19
总计 2,659
