跳转到主内容
发售于2017年11月3日。型号为 A1865, A1901。有 GSM 或者 CDMA 网络制式可选。提供64或者256GB 的存储空间。提供银色和深空灰色。(读音与“iPhone 10”相同)
1202 个问题 查看全部
WIFI on iPhone X isn't working after screen replacement! HELP!
The iPhone X was working fine and no issues with the wi-fi. I put the new screen on and now there are no WiFi networks showing up!
I’ve checked the antenna at the bottom of the phone and that seems fine. Everything else works including the audio without any issues!!
Thanks
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
2个答案
最有帮助的答案
Hello,
When you replaced the screen did you make sure to connect everything back again before assembling it back?. I would suggest you to do it again since there might be something in there that is not quite right. If the antenna is connected, disconnect and re-connect it back and try again. Before you do this, try resettings the network settings on you iPhone and test it again. If this does not work for some reason then try to check the antenna again.
Cheers!
这个答案有帮助吗?
得分 1
添加一条评论
What was the solution?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Rc Noobs 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 24
总计 1,883
