跳转到主内容
加入维修社区 - 创建账户
Xbox One 手柄在2016年随着 Xbox One S 的推出而问世,并增加了对 Windows 10/11 的蓝牙支持。 该手柄修复了 Model 1537/1697 手柄上的许多设计缺陷,更加可靠。该手柄已被改进版 Model 1914 手柄所取代。
Directional pad not working
A few days ago my little brother spilt milk on my remote and the d-pad quit working. I took it apart and cleaned it and got the d- pad to work in the up and right direction but it still won't work in the left or down direction is there a way to fix this.?
P.s. Also when I shake the controller it sounds like theres something it the controller moving around like a a bunch of small prices but when I take it apart there's nothing.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Hi,
I would not suggest you to take apart the controller if you have no knowledge about repairing things on your own. Take it to the store and see if they can find the problem if not, buy a new one. Most of the time when there is liquid damaged, things will stop working properly and most of the time they are not able to be saved.
Cheers!
这个答案有帮助吗?
得分 0
2条评论:
Thanks man and I know what I'm doing. I've replaced parts on controllers be for.
完成的
My D-pad was not working properly so I dropped drops of alcohol and other cleaners to fix the issue and at the beginning it worked but then It started failing again so I did it again and this time the left direction is dead. I sent it to be repaired and they told it couldn't be salvaged yet they repaired the thumbsticks just to force me to pay them
完成的
添加一条评论
添加你的答案
Michael Cox 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 5
过去 30 天: 15
总计 2,596
