跳转到主内容
Nintendo’s first major revision of the 3DS released to Japan in October of 2014 and to North America in September of 2015. The 2015 3DS introduces improved 3D capabilities, a C-Stick, new internal amiibo support, and a new set of trigger buttons.
84 个问题 查看全部
New 3DS has no power nor power lights.
The battery has a lot of corrosion and the console wont show any signs of life even when plugged in. I am wondering, is it the battery PCB, or is it the charging port? I dont know where to start, no water damage has ever happened.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
It could be the battery, i suggest maybe taking it in somewhere and see if they can replace the battery or at least get you a new one. Try taking the battery out and having a look before you take it anywhere first. Orr it could be a broken charger?
这个答案有帮助吗?
得分 1
4条评论:
I bought a new charger, definitely, the PCB needs replacing AND the battery, but the console should still turn on while plugged in. The issue I'm facing is that, should the console still turn on with a broken PCB (ABXY)?
完成的
yeah no i dont think it'll show any life signs until it's replaced. weird you would think a new 3DS would be perfectly fine
完成的
@dest1ny I replaced the PCB, blue light but no screens :/
完成的
dang, maybe it's the screen itself? it could be cracked internally. that happened to one of my tablets once
完成的
添加一条评论
添加你的答案
RedstoneRock 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 4
过去 30 天: 5
总计 256
