跳转到主内容
Scientific calculator by Casio with 252 functions and full dot matrix display. It also features a Replay function and seven variable memory.
repairing of shift button in calculator
how to repair shift button in calculator
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
What's wrong with it? Not working at all? Did you spill anything on it? Did you open the calculator up to look inside? Did you try to clean the contacts yet?
完成的
添加一条评论
2个答案
  1. If you have had this calculator for some time it may be a hardware problem where there is a bit of graphite from the button on the board stopping it from receiving the input carefully clean if it comes apart or use contact cleaner.
  2. If it is a multi function calculator try going through the modes and get to to RAD or check the second function priorities. If none of that works hard reboot by taking out the battery.
这个答案有帮助吗?
得分 0
添加一条评论
সুইচ কাজ করছে না
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Hasnain Ahmed 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 35
总计 3,473
