跳转到主内容
2017年9月22日发售。型号有A1864,和A1897,可选GSM 和 CDMA 网络,存储有64GB和256GB,颜色有金色、银色和深空灰色。
678 个问题 查看全部
iPhone 8 Plus - Not turning on/Connecting to iTunes
Hello everyone!
I have an iPhone 8 Plus here that seems to be dead. I’m taking a look at it for a friend of mine and I would appreciate any help, assistance or advice.
A few months ago…
  • She had dropped her phone and the ringer switch was dented. She used a toothpick to push it back into place and now it is fine.
  • A little bit after that time, the phone would randomly start restarting. While she was using it, the screen would turn into the black “powering off” screen with the spinning spiral, and then would restart automatically.
Couple other things:
  • She does use a third-party lighting cable to charger her phone
  • She once did have some dust stuck in her charging port, and she used a toothpick to remove it.
  • When she was last using the phone, it was somewhere between 70 - 80% battery when it randomly died.
  • There are no cases of water damage, the screen is not cracked, and has not been replaced before.
  • Her battery health (not battery level) was at 87-90%
  • She’s had this phone for about 3-4 years.
  • She uses AT&T
Here’s the problem:
  • The iPhone does not turn on
    • When plugged into a charger, the phone is not responsive. Same thing with a computer, the phone does not display the apple logo, or the battery low, or charging logo. The computer also, does not recognize the phone is plugged into it. She has also tried holding the lock/power button and volume down, to try a force restart but that also did nothing. Saturday, we will try wireless charging to see if the phone decides to respond. I also have a voltage/amp reader so we’ll test any battery problems too.
  • Personally, I think this may be due to a bad battery or damage to the Tristar IC chip, but I was wondering if anyone else in the community had any previous experience to this problem.
Thank you for taking the time to read through this!!
Update:
The wireless charger did nothing. The phone did not boot up. However, when i plugged the phone into a portable Anker powerbank with power IQ, the powerbank did automatically turn on, which means the phone did start taking in power.
Update #2:
Changing the battery also had no effect on the phone :(
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
First of all the iPhone 8 Plus is a little over a year and a half old and considering that it dies at high percentages and bootloops I would try a new battery first and hope for the best.
这个答案有帮助吗?
得分 2
5条评论:
thank you!! will be trying this one :)
完成的
If no go for battery I would say charging chip next suspect. Will have to send the phone to a microsolderer to fix.
完成的
@benjamen50 @phone_guy New battery had no effect. Any other ideas?
完成的
It kinda sounds like a charging port issue but the chance of that is pretty low. Otherwise it’s most likely board related.
完成的
If it was charging port phone would turn on with a charged battery with the charging flex unplugged.
完成的
添加一条评论
添加你的答案
Ryan Ho 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 82
