跳转到主内容
苹果AirPods是于2016年12月发布的无线耳机。
94 个问题 查看全部
The magnet (or mechanism) holding down the lid seems to have broken
I dropped it from seat height and heard a crack as it hit the ground, now the lid has something rattling inside and the magnet (or whatever the mechanism is that holds the lid shut, magnetic or not) doesn’t keep the lid closed as well and opens often in my pocket. The lid opens with a slight swing, there seems to still be some retaining of the lid in place, but it’s far weaker than when I got it. Otherwise the issue does not affect the listening nor the charging and I wouldn’t mind if this was impossible to fix.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
It sounds like the magnet that holds the lid down came out when you dropped it. That's what's rattling inside. Due to the unrepairable nature of AirPods, you probably can't fix it. Looking at this guide, getting inside looks like quite the procedure. However, if you have nothing to lose, you could try to open it up and fix it. You could probably super glue the old magnet back in place. If they still work fine though, I wouldn't risk it. Maybe you could put some velcro on both parts of the lid to hold it down?
Good luck!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Richard Rassokhine 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 4
总计 38
