跳转到主内容
Why won't MacBook Air charge in Spain?
So here's a long running mystery I've faced. For several years now my Macbook Air charges perfectly in Russia. Yet every year when i go to Spain I have problems. At first it charges. Then some days it charges, but others it doesn't. Eventually it just stops charging altogether. I return to Russia and it works perfectly again. I thought maybe temperature was the problem, so I chilled the magsafe 2 charger. But no success.
Any suggestions as to why my charger is travel sick???
Regards.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
You likely have a fake charger! A real charger wouldn’t have an issue jumping between the different AC power systems:
  • Russia - 220-volt
  • Spain - 220 or 225 volts
Review this Apple T/N Apple Portables: Troubleshooting MagSafe adapters to make sure you don’t have a bad cable, a dirty or damaged connector interface.
Here’s a bit more on fake chargers: YouTube - Real vs Fake Magsafe 2 Charger Macbook Pro & Don't Replace Your MacBook Charger With a Cheap Knockoff
Buy directly from Apple to be sure!
这个答案有帮助吗?
得分 1
2条评论:
Thanks Dan. That might well be the issue then. My charger is indeed from an unofficial source. But it's always worked fine so I never anticipated it could be the problem. It's so random how it works intermittently when abroad.
完成的
I've seen this before! Spain is tricky as some locations are 220 all of the time and some will be 220. Then if the grid is struggling you can find that location jumps around between the two as the power company alters the sources around.
完成的
添加一条评论
添加你的答案
Neilh 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 4
总计 395
