跳转到主内容
Model A1418 / Mid 2014 / 1.4, 2.7 & 2.9 GHz Core i5 or 3.1 GHz Core i7 Processor
50 个问题 查看全部
Will Not Boot, Hangs at Apple Logo/ Mostly Loaded Progress bar.
The device originally became very, very slow— once logged into any user account it took forever to open software, complete basic commands, etc.
Ran disk utility in recovery and came back with a fsroot tree error.
Re- formatted the drive and reinstalled MacOS.
Device then would boot OK— no immediate issues seen. Device owner then picked up iMac.
Contacted by the owner one week later. She states it was OK for a short while (she says she used it for just a few hours). One evening owner shut down the iMac. Upon startup the next day, the device is stuck at the Apple logo. Progress bar loads to about 99% and hangs.
Attempted to boot- up myself, saw same results. Let computer hang at 99% progress bar, came back about 45 minutes later and was showing user account log in screen. I can see cursor blinking in password input field, but cursor was frozen. Switched out keyboard/ mouse combo to confirm, same issue.
Was able to boot into external drive running Mojave on said computer. No issue with that same original keyboard and mouse. MacOS on external works just fine.
Ran Apple diagnostic. Came back clear.
Decided to replace hard drive. Installed Mojave on internal drive from another computer before replacing. Tested HD would boot OK. After installation of new known- good bootable HD, computer still hangs at progress bar at Apple logo.
Ran Apple diagnostic. No issues found.
Attempted to boot from the old HD on my own personal MacBook  (which I originally assumed was corrupt) and I just get the prohibitory symbol. My Mac is running 10.14.6.
Decided to format and do a clean install of Mojave on new internal drive on client computer on last time. After install, was able to set up user account and load user account just fine.
Shut down the computer, attempted to reboot normally. Computer still hangs at progress bar in the same fashion.
My only thought at this point is the logic board. But I have no idea why I would get the prohibitory symbol with the original HD.
Edit: Upon a suggestion below, I wiped the drive and installed an earlier version of MacOS (El Cap) And now it’s working just fine. Rebooted several times to confirm, no issue. Is it possible that something happens to this computer everytime it tries to get on 10.14.6?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Jessica,
Have seen this behaviour on an iMac with a Mojave installation twice on same machine…it simply would not run under 10.14!! It would upgrade/install just fine but just hang on restart/boot as you describe.
You might try to install High Sierra and see how that runs.
Good luck.
这个答案有帮助吗?
得分 0
5条评论:
I truly appreciate your reply. Going to go ahead and give this a shot. Will update.
完成的
Ok. / On the iMac i mentioned, there might have been something in the User data migrated over. User had lots and lots of "add-ons". I did NOT try a clean install of Moja on a wiped drive. Good luck.
完成的
It booted just fine with El Cap. What in the world would cause something like this?
I restarted several times to confirm.
完成的
Did you erase the drive before installation? Might try to upgrade one version at a time, up to Hi-S. (knowing Moja didnt work). Yes, very strange. I have no answer.
完成的
@macologist I did format the drive everytime I did an install. I've been testing the computer since last night running El Cap and it appears to be working fine.
All I can tell is that anytime this computer updates to Mojave then the issues start. I ran Disk Util on an external and everything comes back clear. I don’t know personally if bad RAM can cause the initial fsroot tree error I saw, but I suppose at this point it doesn’t matter because the memory is onboard anyways. My only next logical conclusion if the GPU should the issue persist.
完成的
添加一条评论
添加你的答案
Jessica Weber 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 4
总计 1,273
