跳转到主内容
The Chevrolet Equinox is a compact crossover SUV from Chevrolet based on General Motors's Theta unibody platform, and introduced in 2004 for the 2005 model year.
130 个问题 查看全部
How does one fix a power window that does not go up or down
how does one repair a window that does not go up or down in 2005 equinox
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
1条评论:
Do you hear a motor spinning or any other noise when you toggle the switch ?
完成的
添加一条评论
2个答案
The motor that drives the window regulator may be faulty. Or the switch may be bad. You’ll need to pull the door interior off and explore the window motor wiring harness for proper voltage and operation from the switch. If this is a rear window, make sure the lockout switch on the drivers door isn’t engaged. Most new cars have that and it always get inadvertently overlooked and engaged.
这个答案有帮助吗?
得分 0
添加一条评论
It’s often broken wires between the door and post. Open the door, and pull back the boot surrounding the wires.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
George De Witt 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 16
总计 1,229
