跳转到主内容
Released in 2015, the all-in-one camera featuring WiFi, Bluetooth, and waterproof capabilities. This camera lacks the touch screen display of the Hero+ LCD.
10 个问题 查看全部
How to permanently disable wifi and HeroPlus bluetooth cards?
I work near very sensitive equipment and wifi and Bluetooth interfere with our measuring devices.  However, we need to take extremely high quality videos of our work so GoPro HeroPlus is great.  We must physically and permanently disable the wifi and Bluetooth.  Any help is greatly appreciated.  The other camera is the GoPro Fusion 360.  We need to do the same with that camera.  Thanks. Jim
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Jim, have you found a solution? I have the same need.
完成的
添加一条评论
1个答案
已选择的解决方案
Hi @corkgiants ,
Have you checked in the camera’s settings menu area if turning off the WiFi/Bluetooth is an option, you didn’t say?
This is from the manual to turn on the WiFi so hopefully you can also turn it off. Further on it states to do the same for Bluetooth:
1. Turn on your camera’s wireless:
a. Press the Mode button repeatedly until you get to Settings, then press the Shutter button to select it.
b. Press the Shutter button repeatedly until you get to Connections.
c. Press the Mode button to highlight Turn On, then press the Shutter button to select it.
d. Press the Mode button to highlight Yes, then press the Shutter button to turn on wireless.
e. Press the Mode button repeatedly until you get to Done, then press the Shutter button to select it.
这个答案有帮助吗?
得分 1
1条评论:
@jayeff - thank so much for your answer, it is a good one. However, the key to my question is: "We must physically and permanently disable the wifi and Bluetooth."
Has anyone dared to removed the WIFI chip from the motherboard and kept the camera operational?
完成的
添加一条评论
添加你的答案
Jim Cork 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 11
过去 30 天: 21
总计 407
