跳转到主内容
苹果官方于2015年9月25日正式发售iPhone6S A1688/A1633机型。 此机型的修理方式与先前几代差不多, 需要螺丝起子及撬棍工具。 同时也适用GSM or CDMA/16, 64 or 123 GB/ 银色, 金色, 深空灰色, 玫瑰金色等机型。
2690 个问题 查看全部
iPhone wont turn on after screen and battery replacement
backstory on iPhone: I dropped my phone a few weeks back and the screen smashed and touch stopped working I was using another phone as a replacement and let the broken phone die when I tried to charge it to turn it on there was no sign of life not even red battery logo. I have just changed the screen and battery and the phone will not turn on.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
It’s either a replacement parts issue or a logic board issue. When repairing devices, it’s important to have good quality (preferably known-good) replacement parts. Does the phone have the same symptoms with the original screen and battery? If so, then it may be a logic board issue that was caused by the drop.
这个答案有帮助吗?
得分 2
添加一条评论
If you only have a screen problem, you should be able to turn on the phone and use the mute switch a few times to see if the phone vibrates.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
eimearw565 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 3
总计 33
