跳转到主内容
加入维修社区 - 创建账户
索尼电脑娱乐发布的电视游戏主机。于2013年1月20日发布,2013年11月15日上市。
PS4 doesn't boot after taking apart and removing dust
Hi, I recently took apart my PS4 to remove dust from the components, but after putting it back together it doesn't boot anymore. On the PS Forum I was told that I might have damaged the motherboard by touching it since human bodies have a static charge. Now I'm wondering: Should I send it to Sony for 150€ with the certainty of getting a working console, replace the motherboard myself (which is about 170$ alone and isn't guaranteed to be the fix) or just buy a new PS4 Slim/Pro. Thanks in advance!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
you didn't remove any component when you cleaned your console and with what did you clean it ?
完成的
I took every single component out and used a Dyson V10 to remove the dust
完成的
添加一条评论
2个答案
最有帮助的答案
When you mean by doesn't boot does it turn on and get stuck on a blue flashing light, beep turns on for a bit or off or doesn't respond at all?
这个答案有帮助吗?
得分 1
2条评论:
It beeps once, the blue light turns on for ~half a second, and after that, nothing happens anymore.
完成的
Sounds like a bad power supply, vacuum cleaners create lots of electrostatic discharge (ESD) which damages electrical components.
Power supplies die a lot from being vacuumed. The safe way to do it is to use a air compressor or air compressed can which doesn't create static. If the cleaner used had a blow air out (not suck in air) option and that was used that is OK to use.
完成的
添加一条评论
I had this exact same problem but I used compressed air
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Tarek 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 12
总计 750
