跳转到主内容
What RAM Memory I need for HP EliteBook 8440p?
What RAM Memory i need for HP EliteBook 8440p?
i have only 2 GB RAM in it an i would update to 4 GB RAM.
Thank you for herlping.
Franz from Austria / Österreich
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
4个答案
已选择的解决方案
Click on “HP EliteBook 8440p” just under the small picture at right of question page. Then click on “Service guide” at bottom of page (scroll down). Go to page 4-16 in table of content. Bob’s your uncle.
这个答案有帮助吗?
得分 2
2条评论:
Danke :-) Thank You :-)
完成的
Also looks like the builtin ram is under the keyboard and harder to reach but if you upgrade both you can get 8gb total.
完成的
添加一条评论
SDRAM DDR3 PC3-10600 (1 333 MHz)
You can only put up to 4GB per slot
这个答案有帮助吗?
得分 0
1条评论:
You can put up to 4GB per slot, SDRAM DDR3 PC3-10600 (1 333 MHz).
完成的
添加一条评论
Memory Two customer-accessible/upgradable memory module slots 333Supports dual-channel memory 333DDR3 PC3-10600 1333-MHz memorySupports the following configurations:
■8192-MB total system memory (4096 x 2)
■4096-MB total system memory (4096 x 1)
■4096-MB total system memory (2048 x 2)*
■3072-MB total system memory (2048 + 1024)*
■2048-MB total system memory (2048 x 1)*
■2048-MB total system memory (1024 x 2)*
■1024-MB total system memory (1024 x 1)**Brazil 1333-MHz memory configuration
这个答案有帮助吗?
得分 0
添加一条评论
You can upgrade it at 16 GB of ram. Personal I use 2x8 GB ram " integral" 1.35v and he work absolutely fine
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Franz 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 18
总计 2,865
