跳转到主内容
加入维修社区 - 创建账户
The Acer Aspire Switch 10 SW5-011-18R3 is a 2-in-1 Tablet with docking keyboard running Windows OS. It was originally released May 2014.
Device won't turn on
My Acer Aspire 10 won’t power on, though I have an LED power light. I opened up the inside and reattached almost every cable, and it still won’t power on. I have went through almost every tutorial and still cant’t find an answer.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
1条评论:
Try reconnect battery connector (it help me, after that I can power on )
完成的
添加一条评论
2个答案
Solution:
Please follow steps in iFixit guide - I hope, It will be solved easily.
这个答案有帮助吗?
得分 0
2条评论:
@lucasjak Where is the ram slot?
完成的
I'm sorry, the first answer was my mistake, I forgot, that this is not a laptop, but 2 in 1 device. Please, check out a new answer, I hope, it will be helpful.
完成的
添加一条评论
If you haven’t done anything before you notice the problem then it must be related to the ram, you need to remove it, blast air in the slot, clean the ram with paper and put it back.
这个答案有帮助吗?
得分 0
1条评论:
I cannot find the ram slot on this computer. I am pretty sure it has internal ram, and it cannot be removed / replaced.
完成的
添加一条评论
添加你的答案
Max Uchenik 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 20
总计 701
