跳转到主内容
Repair and support information for HP Laptops, designed for home and home office use.
1040 个问题 查看全部
Connecting to a wifi but not others
So my laptop won’t connect to my wifi at home but will connect to my university wifi and other wifis, however at home, all my other devices and family’s devices are connected to the home wifi with no issues… when I troubleshoot it, it says I need to plug in an ethernet cable but thats not really practical for me to sit next my router if I need to use it at home… Any help would be fantastic! Thanks in advance x
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Go into your home router setup and make sure the IP address isn’t blocked, or that you haven’t exceeded the number of attached devices allowed. There may be fixed IPs assigned by the router that you’re laptop is conflicting with. Also check the type of security used, as the laptop may be trying to use a different version of (e.g.) WPA than the router is set to use with new attached devices.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Lisa-Marie Imray 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 3
总计 28
