跳转到主内容
各种形状、大小和颜色的安卓手机的维修指南和拆卸信息。获取DIY修理手机所需的一切。
33613 个问题 查看全部
Phone Screen not Working After Water Damage
Hi y’all, here’s the full story: my phone got wet the other day, so I let it sit in a bag of silica gel packets for a while, until I was able to disassemble it. I disassembled it, dried it out, put it together and it worked… for a while, until the screen went weird and inverted the colors. A bit later, the screen went black altogether (completely black, not even a faint glow emitted). Now, I am able to power up the phone, hear the startup noise, etc, but can not see anything on the display. My friend has a phone that’s the same model, which I borrowed from him and moved my logic board into - and it worked fine, so there doesn’t seem to be anything wrong with the motherboard (this was just a borrow, I can’t take parts from his phone :P ). Is it possible that water seeped in between the various layers of the screen and caused this? Also, I did not see any corrosion on the FPC connector between the logic board and the screen. Any help/advice is much appreciated!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
It’s busted. There’s no coming back from water damage like this usually. Your best bet is to just replace the screen.
这个答案有帮助吗?
得分 0
添加一条评论
Burrying the phone on a bowl or box of rice will help sip the moisture, but this takes about “a week” before you should turn on the cellphone or any gadget. Allowing time to let the moisture out and have it dried completely will save your gadget from short circuit. I’m afraid yours has already been damaged, and best to replace the LCD.
这个答案有帮助吗?
得分 0
2条评论:
完成的
Hello jayeff,
Thanks for the info. But we can use dustproof cover cap jack like what is on this link:
https://www.amazon.com/Black-3-5mm-Headp...
https://www.aliexpress.com/i/33019547554...
or the like. Hence, the phone will be saved from other particles.
Thanks!
完成的
添加一条评论
添加你的答案
David B 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 11
总计 377
