Charger checked using a Fluke multimeter19.6V.Tried a fully charged battery,still nothing,tried total power down then power lead with battery removed,still inop.
In that case. My best bet would be a short in the port or the mainboard. You would have to take it apart and test the port... Unplug the port and then connect your charger and test the end connector of the port and see if the voltage is the same. If it's good then the board has a issue.
How did you test the charger?
由 callmemrfixit 完成的
由 clubair218 完成的
由 callmemrfixit 完成的
Also try with charger plugged in and battery not installed see if it turns on.
由 Ben 完成的
Removed the base and checked the the power at the end connector,OK.Also tried powering up with battery removed,no joy.Suspect motherboard.
由 clubair218 完成的
显示更多的4条评论
