跳转到主内容
苹果官方于2015年9月25日正式发售iPhone6S A1688/A1633机型。 此机型的修理方式与先前几代差不多, 需要螺丝起子及撬棍工具。 同时也适用GSM or CDMA/16, 64 or 123 GB/ 银色, 金色, 深空灰色, 玫瑰金色等机型。
2690 个问题 查看全部
Touch id sometimes stops working after screen replacement
Hello, so i’ve replaced the screen of my iphone 6s and transfered the original home button. Everything went fine, i had set up touch id and was succesfully using it, until next day the phone stopped picking up my fingerprint. I then tried rebooting the device, soft reset, hard reset, but nothing helped. I figured it must be hardware related, so opened up the phone , disconected and then reatached the home button, turned the phone on while it was opened and the touch id was working again. So then i put all the metal plates again, screw in all the screws in, basically seal the phone again, and the touch id stops working again. I assume the ribbon cables aren’t broken, because i could set up the touch id, and it’s also not software, because i erased the phone multiple times, have the latest ios installed. Anyone faced anything like this before? Any ideas on how to fix this?
Update (10/23/2019)
Turns out, all of the screens i bought from china were defected in some ways, and none of them supported touch id
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
When you restart the phone does it come up as a notification that Touch-ID is not working?
And have you tried with the old screen if touch-ID works?
Could be the new screen that has a faulty flex cable for home button.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Matt101 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 41
