Vibration motor does not work anymored after the baterry replacement
After the replacement of the battery the vibration motor stopped working.
Did you repair it yourself or did a shop do it for you?
The component is propably damaged and needs to be replaced,
If the shop repaired it for you they should replace the broken part.
这个答案有帮助吗?
I did it myself based on the instructions posted here. Normally I pay attention to instructions and until now I did not break running components when fixing other equipments.
What would help me is a how-to for the vibration motor in order to check if maybe its contacts got loose, as the vibration was working ok before changing the battery.
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 23
总计 566
Well unfortunately this happened to me as well just replaced battery then vibration stopped working. I looked at it and it was my fault when i was pulling up the main board i must have hit one of the components that power the vibra motor the components is so small about the size of a grain of salt and i am unable and not cordinated well enough to solder somthing that small so i will have to go without vibration but the location of the components on the board is so close to the edge it is my guess the same happened to yours
由 Eric 完成的
