Mac will not stay on, macsafe light turns off after awhile
Hi everyone, I have a late 2013 macbook pro which will not power on. The macsafe light would not turn on:
Some stats
- Macbook Pro working fine and then just”turned off” one day while wife using it
- Opened up macbook and disconnected the power to the battery. Waited a few hours. Connected the magsafe then it would turn on and boot normally.
- Assuming it was the battery I reconnected the battery and turned it on the next day
- Worked for a small amount of time then would turn off
- Removed battery connection again.. waited and then reconnected power (green light would turn on)
- Turn on and would get the grey apple with a progress bar
- Computer turns off after a few minutes. Magsafe no longer powers
Tried SMC Reset
Any ideas?
Thanks
2条评论
Lets get a better view of things here install this gem of an app CoconutBattery
Take a snapshot of the main window with the charger connected and a second with it disconnected. Post both here for us to see 在已经存在的问题里加入图片
Use the same method again disconnecting the battery and pressing the power button, then reckoned the MagSafe charger the charger should be Amber. Then carefully plug in the battery again the system should still continue to work. And now take the first snapshot. Let the system run a good hour then disconnect the MagSafe charger and then quickly take a second snapshot it should state its drawing power from the battery.
由 Dan 完成的
Thank you for your help Dan
Unfortunately I cannot power my laptop until I get to the desktop screen
A few days ago I powered it and it went to the desktop and worked for awhile
A few days later after I would leave the charger out and let (possibly an onboard battery) discharge and power it up I would get the grey apple plus a progress bar that would hang.
Now after coming home from work, I have plugged in the charger into the port, it would go from yellow -> green and then off again.
The computer is now unresponsive....
Could this be the logic board, or the magsafe board?
由 andy 完成的
