跳转到主内容
2.0GHz, 2.3GHz, or 2.6GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.8GHz) with 6MB shared L3 cache.
580 个问题 查看全部
SSD upgrade only 2x link width
Hi I was increasing the space on my late 2013 15” rMBP using the long Sintech adapter and a Samsung 970 Evo (Samsung MZ-V7E1T0BW 970 EVO 1 TB V-NAND M.2 PCI Express) but the link width is only showing as x2 and it seems to be running slow.
I tried SMC reset, format & reinstall Mojave, take it out and make sure its sitting in the adapter and connector right but still no luck.
Does anyone have any suggestions?
Thanks,
Bryan
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
What happens when you put the Apple SSD back in?
完成的
@danj Its back to normal with the Apple SSD back in, seems a lot faster despite both giving me read/write speeds of 500-600 MB/sec in AJA System Test
完成的
添加一条评论
3个答案
已选择的解决方案
If anyone has the same problem. Make sure theres no pins exposed before the gold pins. The tape to cover those pins had shifted on mine exposing the pins. I put a small piece of Kapton tape on the front to cover all the pins and now it works perfectly.
这个答案有帮助吗?
得分 1
1条评论:
Hi, Thank you for the extra info; however do you have a better description about those pin's or having an image to show?
完成的
添加一条评论
Well you found another good reason to stick with a real Apple SSD, Sorry ;-{
Here’s a good guide on the custom SSD’s The Ultimate Guide to Apple’s Proprietary SSDs
Here’s your options
Apple custom SSD:
OWC
Transcend
这个答案有帮助吗?
得分 0
2条评论:
Thanks for the help. I read that guide before buying the drive. I’ll try a few other things before I spend over $400 on another hard drive. Thanks.
完成的
I figured you could still return the SSD and adapter.
完成的
添加一条评论
Bryan
I just upgraded my 2017 MacBook Air 128GB SSD with the Samsung 970 EVO 1 TB SSD. Installation seemed just fine. Performance was weird. The NVMe specs in the “About this Mac” show “x2” links versus “x4” links in my wife’s identical MacBook Air 128 GB laptop (unmodified). Blackmagic shows her Apple SSD “Read” performance is twice my EVO performance — seemed to correlate with the link numbers. So I searched and found your similar finding. Not sure I understood the possible fix, however.
I didn’t understand the description of the piece of tape that covers some pins? All pins in both my long Sintech Adapter Card and the EVO SSD are gold and I got confused about “before the gold pins”. I would very much like to get clear on this and try the fix. Help! Thanks so much for writing about this issue.
John
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Bryan 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 2
过去 30 天: 5
总计 949
