跳转到主内容
A1708/EMC 3164—于2017年6月上市,这台入门级MacBook Pro保留了它的传统功能键(相对于OLED触控条)。
563 个问题 查看全部
Battery charge indicator turns red but not consistent with percentages
The battery indicator turns red when the charge is 15% sometimes it does not turn red when the charge is 5% .Why it is not consistent?. On both the occasions the charging lead is plugged but the power source is disconnected.I need an explanation to enrich my knowledge .Thank you.Narayanan lakshmanan India
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
The best way is to track your usage and the battery condition within Activity Monitor and using this app CoconutBattery.
Unlike other MacBook Pro’s you don’t have a visual charging LED so its hard to know what the charger is really doing. I would recommend getting a USB-C power meter which you place between the cable and your system Satechi USB-C Power Meter Tester
Some of the issues I’ve seen is a bad cable and/or wrong cable. Many USB-C cables are not designed to offer the larger gage wires needed to power/recharge the battery. So you do need to be careful! I strongly recommend you stick with the cable that came with your Apple USB-C charger. Even still over time the cable does breakdown or become damaged, make sure you get a power cable Vs a data cable.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
NARAYANAN LAKSHMANAN 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 210
