跳转到主内容
A1706/EMC 3071—于2017年6月上市,这台13''MacBook Pro以可升级至3.5Ghz酷睿i7动态超频至4.0GHz的Kaby Lake处理器为特征。
276 个问题 查看全部
After OS installation unable to use the machine
OS installation done I have chose the country , after chose the key board layout the we got the error “A Critical Software update is required for your Mac, but an error was encountered while installing this update After that I had connected with WiFi or Ethernet Port and try to update the OS but round and round circle is going on after few second same massage appear.
Please HELP…….
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
3条评论
What is the macOS you are trying to install? How big is your storage and how much free space do you have?
Do you have access to a second Mac as well as a USB Thumb Drive which works across both. Or a USB-A to USB-C adapter cable to interconnect the two?
完成的
I had installed OS version 10.14.5. Installation was completed. Storage is 512GB around 400GB free Space .unable to access the Second Mac
完成的
Why did you reinstall the OS ? Does the touchbar turn on now ? What about keyboard backlight ?
I had the same issue but i didn’t reinstall OS, it happened itself. Apparently Touchbar died and it caused Critical Software update error. It was booting fine in safe mode though, except i did not have touch bar or keyboard backlight at all. I had the top case replaced under keyboard service program. Now everything is fine.
完成的
添加一条评论
1个答案
最有帮助的答案
Well, thats the correct macOS, You’ll need visit an Apple Store to see if they can fix your system. I fear you have a bad flash chip.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Moinul Haque 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 2
总计 498
