跳转到主内容
iPhone 3G是第二代iPhone。型号A1241,有8或16 GB容量,和炫酷的黑色或洁白的白色塑料背面。修复比第一款iPhone更简单。需要螺丝刀、撬撬工具和吸尘工具。
How to replace metal plate/assembly mounted on back of the LCD?
I need to replace the LCD on an Iphone 3G.
When the LCD arrived it did not come with the metal backing plate. Do I simply swap the plate to the new LCD? I did this before and the plate came attached to the new LCD.
Thanks for any help you can give me.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
1条评论
完成的
添加一条评论
1个答案
最有帮助的答案
Take off (pry) the plate from the damaged LCD very carefully. Don't worry if you damage the LCD, just make sure you do not bend the plate. LCDs come with and without the plate. Let us know how it works out!
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
John morris 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 548
