跳转到主内容
Apple 的第三代智能手表,配备可选的蜂窝网络功能,发布与2017年9月22日。
197 个问题 查看全部
Does anyone know what this is?
I don’t know what this is. It doesn’t look to be a part of the original WatchOS. I can’t leave the menu and both options lead back to the same menu. Already tried a force restart by holding both buttons down until it boots back up. I bought the watch like this so I can replace another watch’s screen, but I just wanted to see if I could do anything about this.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
You’ll need to visit an Apple Store for them to reset the watch via the diagnostic port. Just under the strap cavity is an access port so the watch can be put into DFU mode.
这个答案有帮助吗?
得分 1
添加一条评论
That is part of the original watch OS. It appears when you press and hold the side button and then do a firm press on Power Off before letting go. However, it’s strange that a hard reset hasn’t solved the issue. What happens when you factory reset the device? Are you able to? Is it an endless loop no matter which option on which screen you choose??
这个答案有帮助吗?
得分 0
1条评论:
Resetting the device leads to the same menu again. It's a constant loop no matter what I choose or do.
完成的
添加一条评论
添加你的答案
Derek Bryant 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 3
总计 83
