跳转到主内容
Released June 2012 / Core i7 processor with Turbo Boost / Up to 1 GB GDDR5 Video RAM
Password not working when unlocking
I set my laptop password as 4 numbers. When I use the MacBook keyboard to type said 4 numbers, the laptop doesn’t accept them even though the numbers are correctly typed. When I use a mechanical USB keyboard, the same thing occurs. However, on the USB keyboard if I use the numpad on the right side of it, then for some reason it accepts the password. I have checked if the keys work, and the keys all type correctly.
I changed my password to QWER, and it wouldn’t accept it even thought I typed the password correctly into the login page.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
Are you seeing a lock icon on the screen or are you seeing a User login screen for a given user account?
Reference: About the screens your Mac displays as it starts up
完成的
It lets me choose the hard drive to boot into, then once I choose it, a grey background shows and my name asking for the password.
完成的
添加一条评论
2个答案
最有帮助的答案
Probably the keyboard layout on the password screen is wrong, such as used non-US keyboards and resulted in different key mappings.
这个答案有帮助吗?
得分 1
1条评论:
Thanks for the answer, I made sure when I changed the password, it’s on Britain PC and when I type the password on the login screen, it is also on Britain PC
完成的
添加一条评论
I would try using a USB or Bluetooth keyboard to isolate out if the built-in keyboard is not working correctly.
这个答案有帮助吗?
得分 0
1条评论:
Yh the keyboard is bit dodgy, but the numbers for the password on the keyboard all work. When I use the keyboard on google chrome for example, the numbers work and the correct numbers are entered. Also, when I turn my Mac from sleep, the in built keyboard works to unlock it, it only doesn’t work when I boot the laptop from shutdown
完成的
添加一条评论
添加你的答案
Hamza Zaman 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 7
总计 216
