跳转到主内容
发布于2016年3月,是一款同时拥有着iphone 6s般的硬件规格以及4英寸屏幕体积的iPhone。有深空灰色、银色、金色及玫瑰金色四种配色以及16/64GB容量可选。国行型号为A1723和A1724。
1049 个问题 查看全部
Can an iPhone SE logic board be placed in a 5S?
I have a water damaged iPhone SE that doesn’t turn on, and I have an old iPhone 5S that works just fine (screen is cracked but it functions fine). I’d like to see if it’s possible to retrieve the data from the SE, and I’m hoping that I can do this by placing the SE’s logic board in the 5S.
I just want to make a backup of the SE so I can transfer its data to a newer device that I’ll be buying soon, likely an iPhone 7. If there’s any other way of doing this I’m open to suggestions. I unfortunately did not have automatic iCloud backups enabled.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
Nope, The boards are different notably the chargeport and battery.
这个答案有帮助吗?
得分 0
2条评论:
Ah, that’s unfortunate. Would it be possible to transfer just the NAND Flash memory, or am I reaching?
完成的
The SE uses NVMe, while the 5s uses standard SSD technology, it might not be compatible
完成的
添加一条评论
I would try cleaning the SE of its water damage if it was done recent. Putting the damaged SE logic board in a different shell will probably achieve nothing (even if a 5s shell were compatable, which they would be but all the flex cables have different connectors apart from the screen and front cam.)
这个答案有帮助吗?
得分 0
1条评论:
Could deal with losing the front cam but can’t change the flex problems:/
完成的
添加一条评论
添加你的答案
Ian Huff 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 320
