跳转到主内容
任天堂 Switch 是一款可以通过扩展坞在电视和路上玩的游戏掌机。发布于2017年3月3日。
704 个问题 查看全部
Not turning on after screen replacement
I'm replacing a LCD on a Nintendo Switch that was working fine before I attempted the repair but had some spots on the backlight. After trying the new LCD, I was noticing that the backlight turned on for a second but then everything would shut off. I double checked my connections, pushed the LCD connector in as far as it would go but still got the same result. I decided to try the original LCD but got the same exact result as the replacement. Any ideas or suggestions?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
3条评论:
I'm now noticing something strange. If I have only the backlight ribbon cable connected (leaving the LCD cable disconnected), the Switch turns on. But as soon as the LCD cable is connected, the Switch won't do anything. Could there be a short somehow?
完成的
Same thing happened to me currently! I know this might be late but did you ever find an answer?
完成的
I have the same issue. I replaced the lcd connector and now the console doesn't work when the lcd is plugged in... It's really a crappy situation, since the guy who owns the switch is now threatening me.
完成的
添加一条评论
3个答案
Maybe it’s a bad LCD, might try to get a replacement maybe
这个答案有帮助吗?
得分 0
1条评论:
I could try that. But wouldn't the original still work?
完成的
添加一条评论
Well bummer. 4 years after this original question was posted and no clear answer. Hoping this comment will bump this in the algorithm somehow so it can be answered!
这个答案有帮助吗?
得分 0
添加一条评论
I bought replacement parts for my Nintendo switch then disconnected everything then assembled it back together and tried to turn it on and when I did the screen won't show any signs of power, just stayed blank so then I charged it even for a long time and nothing changed. I looked everywhere online and looked at video tutorials and read many articles for my switch and it just don't work. Since my attempt to repair it was unsuccessful then nobody can't repair my switch. It's best to get a replacement switch and cash is limited to me for some time because I have so much things to focus on doing before getting a new one.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Tech Gurus 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 6
过去 30 天: 26
总计 1,306
