跳转到主内容
Released March 2017, Identified by model number SM-J727
15 个问题 查看全部
My phone screen is black after water damage. Repairable?
I accidentally dropped my phone in a sink full of water. After a day of drying it seemed to work ok. A day after that the screen flickered and then went black.
I can still feel it power on (vibration) but the screen is black.
As a minimum I would really like to be able to see the windows/tabs that I have open in the Samsung and Chrome browsers. It would be great if I could use the phone again but I would settle for just being able to see the browser tabs just long enough to write them down and open them on a different device.
Is there anything I can do to accomplish this?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
Send us please some pics from the LCD connector it might have rust built in to it. It probably was unbuilt the first day and it started becoming a problem later. Can you put a flashlight on top of it? The backlight might be fried.
Update (07/24/2019)
Friend I have a confusion, this phone is exclusive to some carriers and the back is different from the others. Don’t know why but if you see the video it isn’t the same lemme find something else
这个答案有帮助吗?
得分 1
1条评论:
Sorry that I am a novice for cell phone hardware (and software). How do I get to the LCD connector for the Straight Talk Samsung SM-S727VL(GP)? I don’t see screws under the battery cover.
完成的
添加一条评论
最有帮助的答案
Check this https://www.youtube.com/watch?v=8fIMSW_j...
这个答案有帮助吗?
得分 1
4条评论:
Thank you. The video says use a hair dryer but the tool they are using in the video doesn’t look like a hairdryer. Do you know what it is or will a hair dryer work too?
完成的
You can use a heatgun, a hair dryer, or an Iopener that i linked to soften the adhesive
完成的
If there is corrosion on the LCD connector, will I likely have to replace the screen or can the corrosion be removed?
完成的
@testeri If its on the board you can clean it off hopefully. Else if its on the display try cleaning it else buy a new one.
完成的
添加一条评论
添加你的答案
Ed Thurston 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 27
总计 452
