跳转到主内容
加入维修社区 - 创建账户
The Panasonic KX-TGEA20 is a phone accessory that is compatible with Panasonic devices. It features a 1.8-inch LCD display with a resolution of 103 x 65 pixels. The navigation key allows for easy and convenient use of the phone.
Phone goes off after one incoming call
Phone will only ring once and then goes off
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
3条评论:
Hi,
Just clarifying.
The phone rings once and then stops ringing. Is this correct?
Is there anyone there if you answer it after the one ring or not?
Can you call out OK and if so is the line noisy?
完成的
My phone rings off after one ring no one there if they ring back it might take a few times before we can answer them We can ring them there is no noise when we do
完成的
Hi,
Have you got access to a corded phone that you can plug into the phone line instead of the Panasonic just to check if the problem is in the Panasonic phone or whether it is connected to your phone service?
完成的
添加一条评论
1个答案
Maybe it’s a battery problem. You might want to check it if it can still supply the power needed. If not, you may consider replacing the battery?
Cheers.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
sheilajohn-49@hotmail.co.uk 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 9
总计 1,370
