跳转到主内容
苹果于2019年5月发布的第七代iPod touch。这款型号搭载可达256 GB的存储和A10处理器。型号A2178。
Is iPod touch 7 gen replacement screen same as 6th generation
does the 7th gen ipod touch use the same screen-digitizer as 6th gen ipod touch
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 3
添加一条评论
5个答案
已选择的解决方案
They might look the same and the same size but they are not the old regime what's a 9.7 size screen in the newer gen has a 10.2 screen so they're a little different little bigger than the old one they do that so if in your situation it breaks you can either buy a new one or a new screen for the same size so I would suggest to get a new 10.2 screen
这个答案有帮助吗?
得分 0
1条评论:
This sounds like an iPad answer, not iPod touch.
完成的
添加一条评论
最有帮助的答案
Hi
its working fine with me, just changed 7th damage LCD screen with iPod 5/6 generation LCD screen, display and touch working good!
Cheers
这个答案有帮助吗?
得分 5
添加一条评论
I just used an OEM refurb 5/6th gen screen on one and it works perfectly. Not sure if aftermarket is the same.
这个答案有帮助吗?
得分 3
添加一条评论
No, it will not work.
这个答案有帮助吗?
得分 0
1条评论:
it works .The 5th gen without back camera might have a hard time fitting in but it works
完成的
添加一条评论
guys I really need help so if you guys could see my question it would be helpful
btw good luck with your ipod
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
todd 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 12
总计 4,099
