跳转到主内容
The Xbox One Wireless Controller model 1697 was released in 2015 and replaced the model 1537 controller and fixed some of the problems found on Model 1537 controllers. The Model 1697 controller includes an integrated 3.5mm headset jack, which allows compatibility with most 3rd party headsets without the need of an adapter. This controller has been discontinued and replaced by the Model 1708 controller.
71 个问题 查看全部
My right analog stick on my Xbox One controller is not responding
So, today I logged onto my Xbox to play some War Thunder. However, when I push the right analog stuck to the right, it does not receive the action I'm inputting. It is only for pushing it right, up, down and left work just fine. Can someone please explain to me what is happening, and what steps I can take to resolve the issue?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
2个答案
最有帮助的答案
Hey. Is this happening only with War Thunder? If so,it is related to the game.
First thing to try,take the batteries out of the controller and hold the power button for 10 seconds,then replace both batteries. See if this works.
Quit the game(right pause button then quit on game from home screen to close app) or take out the disk. Now,you could try restarting the Xbox one(not sleep mode then back on but actually restart it). Although,It’s best to hold the power button on the Xbox itself and wait for it to turn off. This does a full power off. Then unplug the power supply from the wall,and hold the power button on the console to drain the charging brick(about 10 seconds to be safe). Then unplug the brick from the Xbox,then press the power button for another 10 seconds. Now plug it all back in and power it back on. Try it again.
You can also hook the remote up by the wire to the console. Then check if there’s a firmware update available for the controller. See if this fixes the issue.
If none of the options above fix the issue(being it’s not specific to the one game),it’s going to be a bad controller most likely. You can always blow out the joystick with canned air I guess. But I doubt this would fix it in this scenario. Your last option is to take it apart and you can check the little white wheels(2 of them) attached to the joystick. These are variable resistors that allow more electricity to pass depending on how much contact they are making with the circuit. When you move the joystick,it moves these little wheels. If one of them is dirty somehow,it could cause a weird issue. But this would be extremely difficult for someone inexperienced.
这个答案有帮助吗?
得分 1
1条评论:
Thank you. I have tried these, apart from the last one to no avail. It is not related to one game, and another problem popped up. Now in menus, the left analong stick will make the movement skip around by 2 places, so, I think I just need to wait until next paycheck and buy a new one. Thank you for your assistance, I genuinely appreciate it.
完成的
添加一条评论
I know you probably don't care now but I just put a couple drops of 70% alcohol in mine wiggled it and it fixed
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Klaus O 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 20
过去 30 天: 93
总计 9,738
