跳转到主内容
Manufactured from 2004 to 2009, the Vino 125 has a 125cc engine.
22 个问题 查看全部
Vacum, and fuel hoses hooup
I required to clean out the carburetor on my 125 Yamaha Vino, and the vacuum, and fuel lines got mixed up. I need to install them in the right places where they should be, can anyone help with a diagram instruction on where they are attached on the carb?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
I already have that manual, and still the vacuum hose hook-up locations to the carb are not shown, or explained. I had to remove the carb to clean it inside of old fuel residue of 10 yrs. siting idle. Though service manual would cover the subject, before I removed the carb, but later found it wasn’t covered at all. I pretty much had to guess, which hose went where, once I re-installed the carb., and lucky me, I figured the issue out. Scooter runs perfectly again, and fired up on the first turn over, the way I hooked it up…. Thanks for the effort in helping
完成的
添加一条评论
1个答案
最有帮助的答案
Hey va3grp.
Scooters are not my thing, but I did look into it, and found an actual service manual for your model. Lots of useful information and loaded with diagrams that should supply what you need. Just do a search for “YJ125S Service Manual - 49ccScoot.com”, and the pdf manual can be downloaded, or you can simply view it’s contents on line.
Good Luck.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
va3grp 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 6
过去 30 天: 25
总计 1,528
