Why is my tv showing vertical lines on hdmi and tv but not on the menu
Hi,
my tv (sony bravia KDL-46XBR45) is showing vertical lines, all evenly space, but only on hdmi and tv, not on the menu screen.
here are some images
https://i.ebayimg.com/images/g/3s8AAOSwO...
https://i.ebayimg.com/images/g/RT0AAOSwi...
is there anything i can do?
3条评论
Hi,
Did you try different HDMI port, different HDMI cable, different signal source e.g. DVD player, different input source e.g. AV or component video to see if you can isolate the problem?
What have you tried?
由 jayeff 完成的
@jayeff none of the ports work (av, hdmi, tv) they all show the same lines, apart from the menu screen
由 Giancarlo Amico 完成的
Did you find out the fix? I also have thos problem. Evan when i go on youtube on the app webbrozer the picture is perfect except the video box in the middle of the screen has the same lines.
由 Kevin Burke 完成的
