跳转到主内容
Model A1225 / Mid 2007 and Early 2008 / 2.4, 2.8, or 3.06 GHz Core 2 Duo processor
433 个问题 查看全部
Power adapter - multiple choice, please help!
Hi!
My power supply is faulty on my iMac and I need a replacement. The faulty supply inside my 2007 24 inch iMac is a LiteOn PA 3241 02A1.
In my research, it appears that another power supply is also a compatible replacement. A Delta ADP 240 AF B. These seem to have been fitted to the 2008 version of the iMac 24 inch.
Is this the case that either can be used as a replacement for my 2007 iMac?
Thanks for your help!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
Apple contracted both companies (Delta & LiteOn) to make power supplies. As long as you get the correct one for this series you’ll be OK. Here’s a good rundown of the Apple P/N’s per each model. This is from PowerbookMedic’s parts listing 250W power supply
这个答案有帮助吗?
得分 2
3条评论:
Thanks for this information @danj . That’s really useful.
So just to confirm, you mean that any power supply made for the 2007-2009 Intel iMac 24 inch will work fine, it’s just that the Apple product numbers and actual supplies may look a little different? Have I got that correct?
Thanks for your support.
完成的
If it’s helpful. This is my current faulty power supply. https://share.icloud.com/photos/0VsYhICk...
This is the replacement I’m looking at.
https://share.icloud.com/photos/0Np6SZk0...
Thank you.
完成的
As long as its a 250 Watt unit and has one of the Apple part numbers listed you'll be OK.
完成的
添加一条评论
添加你的答案
Sam Harries 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 6
总计 246
