跳转到主内容
Replace Screen OR Logic Board if images are burned into screen?
So I’ve adjusted the “Accessibility Features” for the discoloration and the burn in. It took care of the color issues, but I still have old images burned in on the screen. We use this for work, and it will be on the same screen the majority of the time that the screen is on.
Should I replace the LCD and digitizer? Or is this a Logic Board replacement? Or something else?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
Couldn't tell you unless I had the iPad in front of me and tried another screen myself. To save the trouble of buying another screen with the risk of it having the same thing take it to a reputable repair store to get it fixed.
这个答案有帮助吗?
得分 0
添加一条评论
It sounds like a bad lcd to me. iPads are usually pretty resilient to burn in. But as Ben said,taking it somewhere to be repaired would be wise. Then if they replace the screen and it doesn’t work you can possibly get a refund.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
travisabraham 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 7
总计 189
