跳转到主内容
索尼的新一代电视游戏机,于2013年2月20日发布,并于2013年11月15日开售。
1697 个问题 查看全部
Ps4 Unrecognised Disk. With new laser deck.
Hi ive looked on here already but not sure if my exact problem has come up before. Ive had my ps4 since 2015 and about a year ago it stopped reading disks. Sometimes it might read a DVD movie but very rarely.
I finally decided to fix the problem and stripped it down. I figured a new laser deck (KEM-490) Was probably what was needed. And it was cheaper than buying a whole new drive. So ive swapped it out but im still getting the exact same problem.
The disk doesnt spin at all. All that happens is the laser goes back and forth a few times. The disk readjusts and the laser tries again and then stops. At no point does the disk start to spin up.
Now ive taken the cog mechanism skrews off and removed the magnatised disk peice that holds the game in place and whilst its trying to read taken the disk out the drive manually and there seems to be no laser coming out of the lense? Is this normal? Ive read other places it swaps between blue and red when a disk first goes in.
I just dont know what to try next. Perhaps a faulty cable or the board attached to the bluray drive has gone wrong somewhere? Im at my limit of my skill level/knowlege of this kind of thing here. But i was pretty sure some kind of light should be emmiting from the lense?
Any help would be very much appreciated as im sittibg on about 8 or 9 games that i havent really played and hard pressed to afford the high prices of digital copys of games.
Thanks.
Bish
Update (07/13/2019)
Here is a pic just for reference
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
Ok. I have factory reset it and rebuilt the database. I just dont have the skills for microsoldering. I can just about solder speaker wires! I do have a multimeter but ive only used it for basic thibgs when i used to be a signal technitian on the railway. (Voltage measurements on relays and ohms on testing on track circuits) not got the first idea what i would need to check.
Might just give up and hopfuly the ps5 comes out xmas 2020 or buy a second hand one and just swap my hdd over.
Thanks for your help though, just bugs me being beaten by the %#*@ thing lol. I dont like to leave things unsolved.
完成的
添加一条评论
1个答案
If it was an identical part for sure,you can inspect the cables. But it is likely related to an ic chip or component failure. This can happen,and requires microsoldering. It’s very complex to get into. It requires multimeter testing,microscope,tools,etc. You could check for used parts one eBay and see if there’s one that has a working motherboard.
You can definitely factory reset it too just to make sure it’s not a basic software glitch. And make sure you’re up to date on software.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Ross Bishop 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 225
