跳转到主内容
第六代 iPad 发布于2018年3月。拥有无线局域网和无线局域网+蜂窝网络机型,32GB 和 128GB 两种储存容量可供选择。配备了 9.7 寸的 Retina 视网膜显示屏和 64 位架构的 A10 Fusion 芯片。
194 个问题 查看全部
My iPad keeps powering off after having to change the cracked screen.
iPad 6thgeneration keeps turning off after having the screen replaced when I dropped it and the screen cracked. It works intermittently. Someone mentioned it may be a problem with the digitizer. Can this be fixed?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
Are you using a flip cover that automatically locks / switches off the screen when the screen is covered?
If yes it's most likely going to be a damaged home button cable causing the problem as there is a sensor on there to sense the magnet in the smart cover.
完成的
Yes, it worked fine before having the screen replaced, so I guess I’ll bring it back to the tech again. He changed the screen twice so far.
完成的
添加一条评论
1个答案
已选择的解决方案
Faulty screens can cause weird issues. The lcd and digitizer are one piece. If the circuitry is bad in the screen processor chips(on the flex cable),it can cause weird problems. They could’ve knocked off a component as well on the board. This happens a lot.
Always disconnect the battery prior to repair. Be careful with the tiny components.
Did it work while the screen was cracked? Could you use it regularly otherwise,or did it have the same issue(if you could even test it)?
if it worked despite being dropped,this could be a bad part,or the technician’s fault.
If you did did the replacement,did you follow the above procedures?
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
R Keating 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 14
总计 411
