跳转到主内容
The Galaxy S7 Edge is the curved-screen variant of Samsung's 2016 flagship phone, the Galaxy S7. Announced February 2016 and released on March 11. Model SM-G935.
369 个问题 查看全部
your phone encrypted for security reason enter password to open you ha
after i update my mobile samsung s 7 edge it's start to startup security log in page says your phone encrypted for security reason enter password to open you have 5 attempt to factory rest i have a lot of data on my phone i do not want to lose please help i do not even remember to setup a startup security before what to do
回答此问题 我也有这个问题
这是一个好问题吗?
得分 6
添加一条评论
2个答案
最有帮助的答案
SOLUTION if you have setup a pattern pin lock you have to convert the pattern to numbers. So if you drew a Z in a 3x3 area from top to bottom the password would be 1235789.
Hope this makes sense and helps someone.
Worked for me.
这个答案有帮助吗?
得分 7
7条评论:
thank you that worked for me
完成的
Thanks, it works for me too, but how to change this pattern or password?
完成的
Oh my goodness, I’m so thankful I found your comment. That did the trick for me. I still had to find out the number of dots on the grid (3 by 3 dots), so I could number it correctly. I should’ve been able to tell from the numbers sequence you provided, but I was a little panicked, lol. You would think Samsung would give some guidance like this for anyone that does a pattern.
完成的
OMG! this is so brilliant! thank you for the tips!! been trying to unlock my samaung phone for more than 10x and I keep on thinking, wth is my password?? Did I set it up? And Ive come to realized that the password is my unlock pattern!
完成的
Man... You're awesome. Thank you so much. I can't believe this solution not well known. Your answer deserves more credit.
完成的
显示更多的2条评论
添加一条评论
I find it very strange that an update encrypted your phone. I know the feature exists but you have to manually set it up. Your phone is encrypted by default. This is an extra layer that prevents Android from booting untill set password has been put in.
You can try your unlock code/password/pattern.
这个答案有帮助吗?
得分 4
2条评论:
no i do not think it's the update who encrypted my phone someone set the thing manually and i do not remember i did that or not must be my wife she always doing that kind of staff but she do not remember too
完成的
If you don't know the password there is no way to circumvent it. You can consider your data as lost. Maybe flashing the bootloader and firmware will make your phone usable again. But retrieving your data is going to be difficult/nearly impossible.
完成的
添加一条评论
添加你的答案
Mohammed Alhijjaj 将永远感激不已
浏览统计数据:
过去 24 小时: 4
过去 7 天: 22
过去 30 天: 125
总计 15,242
