跳转到主内容
2015年3月更新的 13 英寸 MacBook Pro 配备 Retina 显示屏,型号为A1502,采用第五代英特尔酷睿 i5 和 i7 处理器,并配备 Force Touch触控板。
My Keyboard Backlight doesn't work
Whenever I try using the F5 and F6 keys to adjust the brightness, I can see on my screen that the brightness is being adjusted but the backlight doesn’t come on.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
You may notice that the keyboard backlight may not allow adjusting with a small prohibition icon being shown in the adjustment window.
This is because there is a setting in MacOS (on newer versions like High Sierra and Mojave) that is switched on to automatically turn off keyboard backlight in rooms that have bright lighting (There is a ambient light sensor for auto brightness right next to the webcam)
That setting can be toggled off under keyboard or power on System Preferences. You can test to see if keyboard backlight turns on because of that setting by blocking roughly around the camera area and see if it switches on.
Otherwise it sounds like bad keyboard backlight diffuser / film which usually only occurs from liquid damage on the keyboard.
这个答案有帮助吗?
得分 4
1条评论:
Thanks for your answer. I tried it and I also checked the settings but it still didn't work. So do I have to replace the keyboard backlight diffuser?
完成的
添加一条评论
添加你的答案
Damilare Ogunmola 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 216
