Model #WTW5640X only works on delicate
9 yr old Whirloool Cabrio washer only works on delicate for the last 2 weeks and just hums on the other cycles. At first I could unplug the washer and plug it in and it worked but that doesnt work now
Does the machine spin fine on all settings? or have problems as well?
Selector switch
If your washer has a selector switch on the control panel, make sure the button for your selection is pressed all the way in, or set properly.
Drive motor
Many washing machines have multiple-speed drive motors. Though it's uncommon, the drive motor may work fine on one speed but not on another. If the drive motor has failed on one speed, you need to replace the entire motor.The motor reg winding can be the problem, on the delicate cycle the motor uses a slow winding, the other cycles use the reg winding
Connector plug
This can also be caused by a loose connector plug. Check that all are securely plugged in.
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 1,700
