跳转到主内容
Can NOT turn on and charging light stays amber
Hey, I cant turn on my MacBook air after probebly running out of power.
No Sound, light or any sign of action other then the amber light on the charger.
resetting the smc turns charger light to green and back to amber.
Letting it charge over Night still amber. Disconnecting battery and pluging in charger does NOT change the amber light to green and still no action.
Hope somebody Can help me
Kind regards Michael
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
1个答案
已选择的解决方案
With the battery disconnected are you able to start the system with just plugging in the MagSafe charger? The system should spontaneously boot.
If it does you'll need a new battery 2015 年初 Macbook Air 13'' 电池更换
Update (07/09/2019)
At this point I suspect your logic board has a problem. You’ll need to find someone local to fix it or you could just replace it MacBook Air 13" Early 2015 Logic Board Replacement has the logic board info inside.
MacBook Air 13" Early 2015 Logic Board图片
指南
难度:
中等
1 - 2 hours
MacBook Air 13" Early 2015 电池图片
指南
难度:
中等
15 minutes
这个答案有帮助吗?
得分 1
3条评论:
Hey Dan, Thank you for your quick answer.
No, when I disconnect the battery and plug in the MacSafe charger, nothing happens and the charger light is still amber instead of green.
完成的
@danj I had the same problem and your answer allowed me to troubleshoot my problem. Luckily it's just the battery. Sorry Michael that you had a logic board problem. Thank you, Dan!
完成的
@evanga2so - Thats great!
完成的
添加一条评论
添加你的答案
Michael Klostergaard 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 5
总计 347
