跳转到主内容
iPad Air Wi-Fi + Cellular, model no. A1475. Available in Space Gray or Silver, with 16/32/64/128 GB configurations.
123 个问题 查看全部
Why is the lcd on my ipad air black and not turning on?
Connector is Undamaged and The logic board circuits do not look burnt out. Also it was working a few days ago and randomly went black? could it have gone bad?
Thinking of just getting a new LCD and front panel. but what if the new LCD is not the problem. Can i return it to IFixit undamaged for a full refund?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
最有帮助的答案
Was the battery disconnected when the display cable was connected and when it was disconnected? Most of the time a backlight filter blows up if the battery was left in when doing so (it doesn’t always leave marks near the screen connector).
这个答案有帮助吗?
得分 2
1条评论:
Thank you Ben for the quick response,
So I had got it repaired by a "professional" about a year ago and he screwed up a bunch of things on the inside of the iPad, in fact out of the 4 LCD panel screws there was only one there. he also did not have any screws on the LCD metal connector holding it down. He even forgot to put the logic board emi shield back on. Initially the problem began when somebody dropped the iPad on solid ground and it went black. I thought some cable went loose on the inside so i cracked it open and i find this scenario. Do you think that because this faulty repair, the LCD could have burnt out?
完成的
添加一条评论
The problem might simply be your screen brightness.
So if you can interact with Siri, try asking her to turn up the screen brightness to the maximum.
use siri to turn screen brightness up on iPhone
ask Siri to turn up your screen’s brightness for you!
See if that makes a difference. If not, keep reading!
Use your device and see if it performs normally.
Perform a hard restart
On an iPad with no Home Button and iPhones 8 or later: Press and quickly release the Volume Up button. Press and quickly release the Volume Down button. Then press and hold the Side/Top/Power button until the device restarts Forced Restart Not Working on iPhone 8 or iPhone X?
On an iPhone 7 or iPhone 7 Plus: Press and hold both the Side and Volume Down buttons for at least 10 seconds, until you see the Apple logo Forced Restart Not Working on iPhone 8 or iPhone X?
On an iPhone 6s and earlier, iPad with a Home Button, or iPod touch: Press and hold both the Home and the Top (or Side) buttons for at least 10 seconds, until you see the Apple logoiCloud keeps asking for password (iOS and OS X); fix
If you see the Apple logo, it’s unlikely the problem is hardware-related but rather was a software issue.
Use your device as you normally would and see if the problem resolved.
Check your temperature for blank or black screen problems
Black or blank screen problems often occur if you operate your device under extreme temperature conditions (like being too hot or too cold)
If too hot, just place your device in a cool area for several hours to let your device to cool down
And if too cold, put your iDevice in a warm area (but not hot) for several hours to allow it to warm up
Using an iOS device in frigid conditions outside of its operating range might temporarily shorten battery life and could cause the device to turn off
Battery life will return to normal when you bring the device back to higher ambient temperatures
Try and always use your iOS devices where the ambient temperature is between 0º and 35º C (32º to 95º F)
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Saad Masood 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 90
