跳转到主内容
HP Color LaserJet CP1215 is a single-function laser printer marketed for small businesses and home offices.
12 个问题 查看全部
The page roller makes a very loud noise
when I am printing, the page roller makes a very loud annoying sound. What can that be, and how do i fix it?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 4
添加一条评论
3个答案
已选择的解决方案
Check HERE (HP's video on noisy printer) ... is that the sound you are referring to?
SOURCE: HP (I work for an HP authorized service provider)
这个答案有帮助吗?
得分 2
5条评论:
video link does not work
完成的
You may want to try again tomorrow. if it's still down... something will happen. Just don't know what right now...
完成的
The link is still down.
完成的
link still does not work
完成的
I tracked down the video he was originally trying to send using some info contained in the link itself.
You can find it here:
https://support.hp.com/us-en/document/c0...
完成的
添加一条评论
In this case follow these instructions step by step:
First check if the toner drum is properly inserted and not lose from any side.
Then try cleaning your feeder rollers by using a C2C solution or use alcohol swabs. Because sometime a jammed roller often causes annoying sounds and cleaning fixes it.
这个答案有帮助吗?
得分 0
1条评论:
I have a konica Minolta magicolor 1600w.I found the terrible squeak was $&*!^$^ from 3 peices of felt In the fuser unit that where pressing against the pressure roller.,over time They get a thick layer of ink on them that turns into shiny plastic jackets.so the shiny plastic jackets pressing on shiny roller as it turned was the problem.I don't know if all printers have theses felt pads but it might be a good thing to check on yours ?.I just took mine apart and sanded them down to remove the jackets.And no more squeak..I hope this may help some of you .cav1066.
完成的
添加一条评论
I just had this problem, then realized, upon inspection of the newly installed cartridge, that I I had left one of the pieces that was meant for removal on the toner cart. Check to ensure that you have removed all packaging from the cartridge before installing!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Monique 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 22
过去 30 天: 94
总计 71,848
