Freezing Leading to Scrambled Screen/Questionmark Folder
(So the mac has frozen two times while attempting to write this message - on the phone now - hopefully this freezing bug is not contagious :D)
Hello guys,
My mac has started to freeze since the last 3/4 days. After the cursor freezes, 50 percent of the time with the rainbow scroll, I close the lid of the laptop and the screen light turns off(I can see from the logo). When I immediately reopen, either a scrambled screen comes, or the laptop seems to restart. When this happens it goes to a flashing question mark folder most of the time or a white screen. I then force restart with the power button and laptop boots up as usual. The first times it seemed to happen when the mac i felt was under load, e.g first time was when football manager was open with a number of safari tabs as well. It also happened when I was scrolling reddit, when i sometimes get a safari notification saying reddit is taking siginificant memory.
However this issue has migrated to instances when there is no load. In the past hour the mac has had this issue 2 times, when the only thing running was safari and the ifixit tab. (Although i had attempted to write these messages straight after rebooting from a crash).
Also in the last crash, i got a message before logging onto computer of a “the system is unable to unlock your login keychain - login keychain is damaged, cannot be used, new one created. Does this suggest an access to memory problems, as I also get the flashing question mark folder occasionally?
Does what I am observing seem to match a common symptom, and if so, is there a potential fix?
Many thanks in advance…
2条评论
Did you get your system wet at some point? Like sit it down on a wet surface or spill a drink in to it?
Are you still using the original SSD drive the system came with?
由 Dan 完成的
Hello (again) Dan.
Yes this laptop had a water spill waaaay back in 2013, which probably led to a previous problem with the laptop. I had consulted with the community about this back in 2016, where you had commented also. That problem was fixed when I took it to a local laptop repair shop, who said that the problem was very dusty.(MacBook keeps on turning off when unplugged, yet battery health is 86%)
It is still using the original SSD
由 Yavuz 完成的
